158595:
sv: sv: Trailer ledblinklys efter Disco 3 blinker konstant med små blink. (19-01-2018 17:29:55) (svar på
158545)
Carsten Pedersen (medlemsstatus ukendt) (
ip-adr: 2.111.77.2)
Correct statement, LED bulbs present a higher resistance to the D3, This means that they draw less current than a conventional bulb,so you need to put a 10ohm 30watt resistor accross (parallel) the bulb to make the circuit draw more current and appear to be a normal bulb.
This will solve the problem.
Note: fitting the resistance in series with the LED bulb will lower the current consumption and thereby not fix the problem.
Hilsen Carsten
