159973:
sv: sv: sv: sv: sv: sv: sv: Extreme steeeing wheel vibration/wobble (19-09-2018 07:44:11) (svar på
159968)
Vladi (medlemsstatus ukendt) (
ip-adr: 212.112.153.146)
Big big thanks to all!
I’ll check the tires, but I’m mentally prepared to go all the way, check for wear and replace if needed: panhard rod bushings, wheel bearings, swivel ball preload, radius arm bushings, steering tie rod ends, etc. etc.
It seems like mud or a tire went bad or just a wheel out of balance could be the reason that kicks off that violent vibration, but it’s main cause must be worn out or dameged components somewhere..
Cheers.
