151124:
sv: sv: Olie på en R380 (26-09-2015 10:52:58) (svar på
151123)
ip-adr: 80.63.102.78)
Hej Ole
Jeg foreslår som Ole skriver, du hælder MTF94 gearolie på. Ikke Dexron eller andet.
TECHNICAL BULLETIN N O : 0007 ISSUE: 2 PAGE: 1 OF 2
ENGLISH
TECHNICAL BULLETIN
MODEL/DERIVATIVE: Bulletin N o : 0007
Range Rover
Discovery / New Discovery
CDS. ref: L8462bu
Issue: 2
Defender Date: 29.03.2000
Freelander
AFFECTED RANGE:
All R380 manual gearbox derivatives - refer to text for specific change points
All Freelander
RE - ISSUE INFORMATION:
Incorrect specification reference deleted from PARTS INFORMATION.
Please destroy your existing copy and replace with this Issue 2.
PROBLEM:
GEARBOX OIL - CHANGE TO SPECIFICATION
CAUSE:
At the following VINs, the original oil fill specification for the R380 gearbox was
changed to Texaco MTF94 high performance oil:
Range Rover - WA 384300
Discovery - WA 752315
Defender - WA 131138
New Discovery - All vehicles
The Freelander PG1 gearbox has used the new oil since introduction of the model.
ACTION:
MTF94 will be recognised by its orange/honey colour as opposed to the red
Dexron II oil previously used, and is now available from Land Rover Parts.
It is now the only oil which should be used for topping up and complete fill on
R380/PG1 gearbox applications.
The new oil is compatible with the old and to enable earlier vehicles to benefit from
its introduction, should be used retrospectively on vehicles prior to the above VINs
for all top up and refill requirements.
Refer to PARTS INFORMATIONoverleaf for details.
Until further notice, current Service Schedule gearbox oil change periods are
retained and must be adhered to.
Mads
