155922: I need your help DLRK - Midtjylland - Brande (18-12-2016 13:26:53)
Sebastian (medlemsstatus ukendt) (ip-adr: 95.166.36.161)
Hi,
First: sorry that I need to write this post in English, but I can't speak Danish.
The Problem:
I tried to remove the fuel filter of a Defender TD5, but I'm not able to remove it just with my hands.
So I've checked in the internet if there are any tools for removing a fuel filter and I've found this one https://www.amazon.de/Öllfilterschlüssel-MAHLE-KNECHT-OCS-1/dp/B0067JORY8
Is there any shop next to Brande (Midtjylland) where I can buy this tool or do you know anyone who can borrow me this tool for removing the filter?
Hope you can help me. Want to change the filter before I'm leaving Denmark (22nd of December).
Br and a great Sunday,
Sebastian
155923: sv: I need your help DLRK - Midtjylland - Brande (18-12-2016 13:53:21) (svar på 155922)
Ole Rasmussen #2919, reg. fyn (medlem) (ip-adr: 94.145.227.48)
Maybe like this
155924: sv: I need your help DLRK - Midtjylland - Brande (18-12-2016 14:01:46) (svar på 155922)
Paul Sehstedt #27, reg. sjyl (medlem) (ip-adr: 212.112.150.102)
Hi Sebastian,
there's a Land Rover Centre in Herning at Rønnebærvej 7-9
They'll be open again tomorrow . You can call them 00 45 97 12 50 11
Work shop manager Jonas 00 45 40 74 46 22
Owner Ole Meldgaard 00 45 40 30 16 83
I can supply you with these phone numbers only, but I'm a regular customer in Herning since 1973.
Give them my compliments.
Best Regards.
Paul
155925: sv: I need your help DLRK - Midtjylland - Brande (18-12-2016 15:35:28) (svar på 155922)
Ole (medlem) (ip-adr: 5.186.123.199)
You can buy the oilfilter tool at every tool or autoparts store. Oles cowboytrick might just mere more than adequate.
https://m.youtube.com/watch?v=0BGLkrdA29Q
155926: sv: I need your help DLRK - Midtjylland - Brande (18-12-2016 16:17:08) (svar på 155922)
Niels (medlemsstatus ukendt) (ip-adr: 83.92.187.18)
In my youth I was a trainee to become a tractor-mechanic. As the youngest trainee i had to do the oil-changes. I learned that the easiest way to remove a spin on oil-filter was to hammer a large screwdriver through it. ;) That way it was no problem to turn the filter. How access is on a TD5 i don't now, but remember not to punch the screwdriver through anything but the filter. ;)
Good luck
Niels
155931: sv: sv: I need your help DLRK - Midtjylland - Brande (18-12-2016 17:17:56) (svar på 155926)
Kenneth Poulsen #435, reg. l-f (medlem) (ip-adr: 80.62.117.246)
NOT on the fuelfilter, there is a risk for contamination in the fuelsystem.
It's ok on the oilfilter.
155933: sv: sv: sv: I need your help DLRK - Midtjylland - Brande (18-12-2016 20:11:44) (svar på 155931)
Sorry!! Must need new reading glasses. I read Oil-filter. Not fuel-filter. My mistake. Sorry.
Niels
155932: sv: I need your help DLRK - Midtjylland - Brande (18-12-2016 19:43:20) (svar på 155922)
Wow - I'm positive impressed. :)
Thank you for all your replies!
I've also posted this topic in your FB groupe.
Jørgen already helped me to remove the filter. :)
Wishing you all nice Christmas party's and a good start in 2017,
Br,
Sebastian
BTW: I also had the idea with the screwdriver but luckily I haven't one here in DK ????
155934: sv: sv: I need your help DLRK - Midtjylland - Brande (18-12-2016 20:42:48) (svar på 155932)
Fine you're on the road again...
Add to your Christmas wish list an oil filter spanner part no DA1117 and an oil filter socket part no DA1176 both from BritPart.
Take Care.
