81898:
sv: sv: sv: sv: sv: RRC abs dataprotocol (15-05-2009 20:10:15) (svar på
81885)
Anders Lindberg Madsen #7561, reg. øsj (medlem) (
ip-adr: 77.212.213.97)
Hej Jacob,
"Misfire på 7. cylinder" - det er fra en liste over fejlkoder på en V8 EFI motorstyrings-ECU... ;-)
Jeg sender lige en PDF senere i aften.
Indtil da - her er koderne til ABS-ECUen:
Code 2-6 - Faulty stoplight switch or wiring. Fuse A5 blown or not fitted
Code 2-7 - Continuous supply to ECU with ignition off. Faulty valve relay or wiring
Code 2-8 - No voltage to ABS solenoid valves. Faulty valve relay or wiring.
Code 2-12 - Front right, too large an air gap or the sensor has been forced out by exciter ring.
Code 2-13 - Rear left, too large an air gap or the sensor has been forced out by exciter ring.
Code 2-14 - Front left, too large an air gap or the sensor has been forced out by exciter ring.
Code 2-15 - Rear right, too large an air gap or the sensor has been forced out by exciter ring.
Code 3-0 to 3-9 - Open circuit in connection from ECU to solenoid valve in booster, or in ECU
Code 4-0 to 4-9 - Short circuit to earth in connection from ECU to solenoid valve in booster
Code 4-12 - Front right, wiring to sensor broken or sensor resistance too high.
Code 4-13 - Rear left, wiring to sensor broken or sensor resistance too high.
Code 4-14 - Front left, wiring to sensor broken or sensor resistance too high.
Code 4-15 - Rear right, wiring to sensor broken or sensor resistance too high.
Code 5-0 to 5-9 - Short circuit to 12volt in connection from ECU to solenoid valve in booster, possible earth fault.
Code 5-12 - Front right, intermittent fault with sensor or wiring
Code 5-13 - Rear left, intermittent fault with sensor or wiring
Code 5-14 - Front left, intermittent fault with sensor or wiring
Code 5-15 - Rear right, intermittent fault with sensor or wiring
Code 6-0 to 6-9 - Short circuit between two connection from ECU to solenoid valve in booster.
Code 6-12 - Front right, no output from sensor, sensor may have too large an air gap.
Code 6-13 - Rear left, no output from sensor, sensor may have too large an air gap.
Code 6-14 - Front left, no output from sensor, sensor may have too large an air gap.
Code 6-15 - Rear right, no output from sensor, sensor may have too large an air gap.
